Read Before Posting in Connection Help
Use this forum for help with:
Before creating a thread
Please check:
Information to include
Include:
Never include
Do not post:
Replace your real password with
- IRC client connection commands.
- Failed connections to
bnc.eggy.net. - SSL/TLS errors.
- Incorrect username, network or password formats.
- IRC networks that will not connect.
- Server and port configuration.
- Networks stuck in a reconnecting or disconnected state.
- Web Chat connection problems.
- IPv4 and IPv6 compatibility problems.
Please check:
- Your client is connecting to
bnc.eggy.net. - You are using
+5000, including the plus sign. - Your username and network name match the dashboard exactly.
- The network exists in your dashboard.
- Your IRC client contains your current BNC password.
- The external IRC server, port and SSL/TLS setting are correct.
- You have tried reconnecting the affected network from the dashboard.
Include:
- Your BNC username.
- The affected IRC network.
- The IRC client or Web Chat browser being used.
- The exact error message.
- The approximate time the failure occurred.
- Whether the dashboard shows the network as connected, disconnected or reconnecting.
- Whether the problem affects every network or only one.
Never include
Do not post:
- Your password.
- A completed connection command containing your password.
- Password-reset links.
- Session cookies.
- Private account credentials.
<password hidden> before posting commands or logs.
