• Already have an Eggy BNC account?
    If you already have an Eggy BNC dashboard username and password, there is no need to register again. Log in using your existing Eggy BNC credentials.
    Log in
Choosing and Applying a vHost
Approved vHosts are selected through the Vhosts area of the dashboard.
Apply a vHost
  1. Sign in to the dashboard.
  2. Open Vhosts.
  3. Browse or search the available hostname library.
  4. Select the vHost you want to use.
  5. Choose the IRC network where it should be applied.
  6. Select Apply & Reconnect.
  7. Allow the selected network to reconnect.
The new hostname normally becomes visible after the IRC network completes its reconnect.
Available options
The dashboard may show:
  • vHosts available to your current account.
  • Premium-only vHosts.
  • The vHost currently in use.
  • Filters or categories for finding a suitable hostname.
Some options may be unavailable because of:
  • Your account plan.
  • IPv4 or IPv6 compatibility.
  • The IRC server configured for the selected network.
  • A temporary hostname or network problem.
Always apply vHosts through the dashboard so the website and live BNC configuration remain consistent.
