• Already have an Eggy BNC account?
    If you already have an Eggy BNC dashboard username and password, there is no need to register again. Log in using your existing Eggy BNC credentials.
    Log in
Read Before Posting in Connection Help
Use this forum for help with:
  • IRC client connection commands.
  • Failed connections to bnc.eggy.net.
  • SSL/TLS errors.
  • Incorrect username, network or password formats.
  • IRC networks that will not connect.
  • Server and port configuration.
  • Networks stuck in a reconnecting or disconnected state.
  • Web Chat connection problems.
  • IPv4 and IPv6 compatibility problems.
Before creating a thread
Please check:
  • Your client is connecting to bnc.eggy.net.
  • You are using +5000, including the plus sign.
  • Your username and network name match the dashboard exactly.
  • The network exists in your dashboard.
  • Your IRC client contains your current BNC password.
  • The external IRC server, port and SSL/TLS setting are correct.
  • You have tried reconnecting the affected network from the dashboard.
Information to include
Include:
  • Your BNC username.
  • The affected IRC network.
  • The IRC client or Web Chat browser being used.
  • The exact error message.
  • The approximate time the failure occurred.
  • Whether the dashboard shows the network as connected, disconnected or reconnecting.
  • Whether the problem affects every network or only one.
Never include
Do not post:
  • Your password.
  • A completed connection command containing your password.
  • Password-reset links.
  • Session cookies.
  • Private account credentials.
Replace your real password with <password hidden> before posting commands or logs.
