Message Previews and Retention Settings
IRC Inbox provides controls for how message information is displayed in the dashboard.
Message previews
The option:
controls whether message text previews are shown in applicable IRC Inbox areas.
Disable this option if you prefer the dashboard to display thread information without previewing message content.
Retention period
Available retention selections are:
The selected period controls the history window used when IRC Inbox reads and displays thread messages.
Saving the settings
After changing previews or retention:
Hiding is not deletion
The retention setting and Hide control are separate features.
Hiding a thread changes the dashboard view and should not be treated as a command to delete underlying BNC log files.
Message previews
The option:
Show message previews in the dashboard
Retention period
- 7 days.
- 14 days.
- 30 days.
Saving the settings
- Select the required options.
- Use Save IRC Inbox Settings.
- Wait for confirmation.
- Refresh the affected thread where required.
